Автор Тема: Remote Controlled Lifebuoy  (Прочитано 1345 раз)
« : 28.07.2019, 20:39:35 »
A revolutionary remote-controlled life-saving device to keep u safe on water
Innovative technology to save lives
The Dolphin 1 Smart Lifebuoy is a life-saving device with propellers and a smart remote control system
Easy operation
The Dolphin 1 is controlled by a simplified remote controller. Users have reported no difficulty when using it for the first time
Powerful propeller & strong buoyancy
- The two propellers can drive the lifebuoy to maximum speed of 10 knots
- The Dolphin 1 provides a buoyancy that is equivalent to 1.5 regular buoys, allowing it to carry two people at a time
Highly visible
The Dolphin 1 is bright orange and mounted with two high penetration flashing fog lights, making the buoy highly visible in over long distances and in bad weather
Injury & tangle free
The propeller is wrapped by a metal shell to protect the user from injury and keep the propellers from entangling with water plants
Reliable and safe
The battery is stored in an independent cabin so that the Dolphin 1 can keep functioning, even if the hull is damaged
Specification
Hull Material   PE plastic
Dimension           (L)115 cm *(W)83 cm *(H)21 cm
Weight           13 kg
Power           Electric water-jet propulsion
Lifetime           30 mins
Buoyancy           22 kg
Max. Speed   15 km/h (9.3 knots)
Communication Range   500 m
« Последнее редактирование: 07.08.2019, 09:58:59 от bigbird »
  • Точка Гостей: 274
[1] 2 3 4
