Автор Тема: The perfect daysailer: the new Saffier Se 27 ft  (Прочитано 1466 раз)
Ultimate speed, high performance and striking looks is what the new Saffier Se 27ft Leisure shows at first sight. Sailing in full control, singlehanded with all sheets and lines at your helm and double digits speed on your display. Combining speed and safety together with her striking looks make the Saffier Se 27ft Leisure the perfect daysailer
The design philosophy: designed with speed and safety in mind
To achieve high speeds she has modern hull lines with a good form stability. This is achieved with a flat underwater section in the hull and a 2.60 m beam. Weight reduction is also important. Aside from building the hull and deck in sandwich and vacuumed she is, as standard, fitted out with a 4.0 Kw Torqeedo engine with Lithium battery and folding prop. The complete electric propulsion is 70% lighter then a comparable diesel engine alone. The solid lead keel gives her a high righting moment and combining this with a powerful rig, the Saffier Se 27ft Leisure is able to surf and stay in full plane downwind, while pointing high and fast upwind.
Specifications
Length 8.2m                          Width 2.6m
Depth shallow 1.05m              Depth standard 1.4m
Depth race keel 1.6m             Total weight 1900kg
Weight keel 750kg                 Weight race keel 1000kg
Total sail area upwind 49m     Mainsail 24m
Seftacking jib 15m                 Jib 108% 18m
Genaker 66m                        Code zero 51m
Number of spreaders 2           Mast height above waterline 12m
Type of engine Torqeedo 4.0 KW Electric or Yanmar 2YM15
Capacity diesel tank 45l         Capacity watertank 80l
Number of Berths 4               Trailerable Yes
Certification CE norm according to coast C
Super easy handling, all ropes direct at your helm and being able to trim any trimline at all times without leaving the helmsmen position is critical to enjoy easy and safe sailing. A well arranged, ergonomic, sheltered and self-draining cockpit is another key factor on the sailing qualities and comfort to have a great day on the water.
Key Features
- Fast, downwind and upwind
- A high stability ratio keeping her safe at all times
- Multipurpose; Electric or diesel engine, tiller or helm, three different keel options
- Customising; you choose colours, material sails, what propulsion.
- Large ergonomic cockpit with sundeck
- Inside room for 4 persons to sleep
- Can be used on any kind of water, ocean, seas and lakes
- Easy trailerable
- Only the very best materials used. No compromises!
- Designed and built by the largest manufacture world wide in luxury day- and weekendsailers.
  • Точка Гостей: 533
