Автор Тема: Storm Gloria generates the biggest wave ever recorded in the Mediterranean  (Прочитано 1125 раз)
On January 20, 2020, Spain's Ports of the State announced the largest significant wave height in recorded history in the Mediterranean Sea
According to the Spanish meteorologists and oceanographers, Storm Gloria generated a record-breaking significant wave height of 8.44 meters (27.69 feet) off the port city of Valencia, in Spain.
The previous significant wave height record in the Mediterranean Sea had been set at 8.15 meters (26.73 feet) and was recorded in 2003 in Mahón, Menorca.
The authorities estimate that this time, Storm Gloria produced waves of 13.5 meters (44.29 feet).
Storm Gloria, which continues to affect much of the western Mediterranean, including France and Portugal, has already smashed several significant wave height records according to the network of deep-sea buoys.
This historical maximum, the highest data measured in the western Mediterranean, has been obtained by an ocean buoy located near Valencia.
Significant Wave Height
The significant wave height parameter is equivalent to the mean wave height of the highest third of the waves and coincides with the height of the waves that an experienced observer would estimate at any given moment in the sea.
On the other hand, the significant wave height measured by ocean buoys is a critical statistical parameter transmitted in real-time via satellite to describe the swell position in relation to the coastline.
However, the height of a wave by itself is not as representative as significant wave height, i.e., measuring a large individual wave in the open ocean does not mean that it will arrive at the coastline with the same size.
Gloria's effects have also been noticeably felt inside the ports.
In the Port of Valencia, the tide gauge reached a significant wave height of 2.11 meters (6.9 feet) and a maximum wave height of 3.28 meters (10.76 feet).
This is also the maximum record ever recorded by this station since the installation of the sea level sensor in 2006.
These have not been the only wave records beaten during the passage of Storm Gloria.
The Dragonera buoy, in the Balearic Islands, also belonging to the deep-water buoy network of Spain's Ports of the State, also recorded a historical maximum since it was put into operation in 2006.
On January 20, at 3 am (local time), the buoy registered 7.97 meters (26.14 feet) of significant wave height, beating its previous record of 6.33 meters (20.76 feet) obtained in January 2017.
This buoy provides maximum wave height data in real-time and delivered a new record of 14.2 meters high in the same period.
A Deep-Water Buoy Network
The Spanish deep-water buoys are anchored in open waters, at depths between 400 and 2,000 meters (1,312-6,561 feet).
They are equipped with a wave sensor, weather sensors (wind, air temperature, and atmospheric pressure) at about three meters high, and oceanographic sensors at three meters of depth (currents, temperature, and salinity).
In the upper part, they carry luminous beacons, and their position is communicated to the Marine Hydrographic Institute for signaling in the nautical charts.
These buoys are not adrift but, instead, have a complex anchoring line that keeps them in a fixed position.
Every hour, the wave sensor records a 30-minute wave log.
The data produced is complex and cannot be transmitted in real-time. Instead, it is stored onboard, and processed inside the buoy by a computer.
The system performs a statistical analysis of the information and calculates the so-called "integrated parameters": significant wave height, average wave period, average ave direction, etc.
These wave parameters, along with extra meteorological and oceanographic data, are sent by satellite in real-time, since the buoys are too far from the coast for radio communication to be effective.
The buoys' maintenance is performed every four or six months.
That's when the buoy is completely revised: the anchoring line, each and every one of the sensors onboard, batteries, satellite transmission systems, light beacons, electronics, and structural parts.
Then, the raw data that is stored aboard the buoy is downloaded for later analysis in Spain's Ports of the State.
The biggest wave ever recorded was documented on July 9, 1958, in Lituya Bay, on the southeast of Alaska. It measured measured 1,720 feet.
« Последнее редактирование: 25.01.2020, 08:38:13 от bigbird »
  • Точка Гостей: 525
