Автор Тема: I-carbon, when innovation meets design  (Прочитано 1555 раз)
« : 14.04.2021, 19:11:31 »
I-carbon was born from a lucky coincidence: 4 friends linked by a passion for offshore sailing and for the sea, who pool their professional skills, their business experiences, to create a company focused on the innovation of processes. From the automotive and aerospace, the most advanced design, the most innovative materials enter the production of best equipment for yachts and super-yachts: a new approach to industrial processes, to promote mass production and thus reduce time-to-market and costs to customers of each product.
The best carbon and metal alloys accessories for boats are available for designers and shipyards with pricing and timing matching the current needs, to move forward an industry such as the nautical one, generally codified and conservative in its construction procedures.
I-carbon looks forward and collaborates with universities in projectworks that integrate digital control in the use of its carbon products, to keep its proposal to nautical market always new and attractive. The possibilities on the horizon are open only to those who know how to navigate.
Mooring system - carbon fibre
The curved shape and smooth edges allow an easy clamp of the mooring line, avoiding rope consumption. It means no more ropes damaged by sharp edges. The top part of the cleat is made of light carbon fibre, by innovative SMC moulding technology. All the fittings and deck base are made of CNC machined titanium, to offer the best strength, lightness and keep it free from corrosion. It is the stronger and lighter cleat on the market (compared with others of the same size). You can install this cleat on every kind of deck surface, composite, GRP, aluminium, steel, or wood. It is easy to install onboard and does not require drainage due to the O-ring seal between the stem and the cylinder.
Features:
  • Outstanding and sleek design
  • Smooth edges
  • Carbon fibre top cleat
  • Clear matte / glossy finish coating
  • Titanium fittings
  • Totally free from corrosion
  • Extremely light-weight and strong
  • High load capacity
  • Watertight stems
  • No drains required
  • Easy installation
  • Low maintenance
  • Functional, reliable, seaworthy
  • Made in Italy
Awning system
Our poles are made of carbon fibre, with an anti-UV clear coating, they can be painted with custom colours as well. They are manually operated and the awning tension is given by an internal tackle made with Dyneema rope and low friction rings. We conceived an innovative deck base, made of AISI316L stainless steel, easy to install on every deck surface on every boat, with minimum impact on the hull and without drainage (patent pending). It is the smallest foundation available on the market. They are available with a single or double attachment point. The awning is made by Soltis 86®. Other fabrics can be available on request.
Features:
  • Carbon fibre poles
  • UV protective clear coating
  • Custom colour available on request
  • Extremely lightweight and strength
  • Available size: Ø 45 mm, Ø 66 mm, Ø 86 mm
  • Custom size available on request: up to Ø 120 mm
  • Internal tackle with dyneema rope and low friction rings
  • Patented deck base
  • Quick and easy handling
  • Double attachment available on request
  • Lighting system available on request
  • Wide colour choice for the awning
Fender system
With our quick lock devices, they are easy to handle and to deploy. The vertical frame is linked with the deck base and the gas spring on the back allow the fender to suit the movement of the boat. The roller fenders are made of high-density EVA, to provide the best protection to yachts and tenders. They can be adjusted to suit any transom and balcony profile.
Features:
  • Innovative technology
  • Jointed vertical fender, linked with gas spring
  • EVA roller bumpers
Stanchion system
They are conceived especially for superyachts, for deck areas, helipad and balconies. They are clear coated, glossy or matte finish, but can be custom painted on request. They are supplied with soft or hard rigging according to the project specifications.
Features:
Sourse
  • Точка Гостей: 525
