Автор Тема: Peacoq - a sports boat with a catchy look  (Прочитано 1048 раз)
« : 07.12.2021, 21:42:52 »
Very soon a new boat will be on display at the famous yachting exhibition. It is distinguished by its design, approach and philosophy. Meet Peacoq!
Peacoq is a sports two-seater boat with steerable hydrofoils. Combining speed and lightness, the Peacoq redefines the traditional way of sailing small sport yachts.
Where will Peacoq be seen live?
The first boat shows to a wide audience will take place at the Boot exhibition in Dusseldorf! It will run from 22 to 30 January 2022. It is there that you will be able to contemplate this wonderful device.
Let's be honest that this boat has a pronounced futuristic design, which is not suitable for everyone. But if you appreciate the extraordinary shape of the hull, smooth, but at the same time "elastic" lines, as well as the very wings - the boat will definitely suit your taste.
The design was developed by MMProcess. The company has created a great design for the boat, which is created to introduce sailboats to wing boats. This is even said in a press release: "First of all, we want to give all sailing fans an opportunity to discover the thrilling sensations of flying on the water." Hence, this is the challenge Foily has set for itself with Peacoq.
Speed and agility
Thanks to the hydrofoils, it feels like the boat is literally floating above the water.
The maximum speed of the boat, however, will not leave anyone indifferent either. She is 20-25 knots on full courses, 18-20 knots in sidewind. The wind speed required for a start and a steady ride is 7-8 knots for one person and 10-12 knots if you have a partner.
Peacoq characteristics
The MMProcess hand is visible almost everywhere. For example, the beveled bow and convex contours have become a distinctive and striking feature.
What's more, the deck is minimalist and virtually uncluttered. Anti-slip seat pads for yachtsmen provide maximum comfort and convenience.
The main advantage: the wing adjustment system. Thanks to this system, you can steer the boat both in “flight” mode and in classic displacement mode. In addition, this unique fender adjustment system guarantees a high level of safety and allows you to select the optimal control mode.
The weight of the boat, excluding the trailer, is 140 kg.
Body materials
Composite elements are infused at the Sisco Composite plant. Fiberglass, foam and epoxy are reinforced with carbon layers to ensure the lightness and rigidity needed to maintain shape.
Sisco has a wealth of experience in the maritime and aeronautical fields, which guarantees an excellent level of quality.
As a result, FOILY plans to produce about twenty boats a year. By the way, the boat that will be on display in Dusseldorf is the first of 12 boats planned for 2022, of which six are still available. The first five boats were sold in Germany, Switzerland, Italy and France.
topic Что такое кабельтов
10.05.2024, 23:13:39
topic Какова солонина на вкус
10.05.2024, 23:10:45
10.05.2024, 22:57:56
09.05.2024, 14:36:57
09.05.2024, 14:30:56
09.05.2024, 14:24:16
08.05.2024, 11:40:02
topic Немного о ветре
07.05.2024, 16:13:37
06.05.2024, 23:51:36
05.05.2024, 00:07:47
608 Сообщений
  • Точка Гостей: 550
5 6 7 8 9 10 [11]
