Автор Тема: Dinghy from Yamaha: the main ace of this winter  (Прочитано 1086 раз)
Dings, tuziks, tenders - as soon as these boats are not called. But we can say for sure that the dinghy market is full of offers like never before. And Yamaha keeps up with the trends and presents the YAM TAf series.
What is Yamaha?
For more than 65 years, Yamaha Motor has been capturing the hearts of powerboat enthusiasts. And she continues to expand her range. The new products of the company are very practical inflatable YAM TAf tuts.
The frame of the case is now aluminum, which gives even greater strength and reliability. In addition, the YAM TAf dinghy has become even lighter. Thanks to this, controllability has increased, and the power required to set the dinghy in motion has decreased.
Of course, it is worth noting separately the V-shaped case. It provides good streamlining and aerodynamics.
Model range YAM TAf
There are three models of YAM TAf: small, medium and large. So let's take a look at each.
Shustra baby YAM 270TAf
The smallest tuzik is YAM 270TAf. With an overall length of 265 cm and a weight of only 41.5 kg, the dinghy is designed for three adults and one child and can be powered by an 8 hp outboard motor.
Specifications YAM 270TAf:
Length   2.65 m
Width   1.59 m
Capacity   3 adults + 1 child
Engine power   5.9 kW/8 HP
Folded dimensions   251 x 111 x 47 cm
Floor material/type   Aluminum
Case weight   48 kg
Maximum load capacity   425 kg
starting price   £1,900
As a gift with this model you will receive a pair of aluminum oars to use YAM 270 TAF as a rowboat. Prices on YAM 270TAf start at £1,900.
Confident YAM 310TAf
Model YAM 310TAf is considered average and is designed for four adults and one child. This version of the dinghy is equipped with a 20 hp motor. and has a more rigid “deck” that makes it easier for an adult to move around.
Specifications YAM 310TAf:
Length   3.07 m
Width   1.59 m
Capacity   4 adults + 1 child
Engine power   14.7 kW/ 20 HP
Folded dimensions   279 x 111 x 47 cm
Case weight   57.8 kg
Maximum load capacity   495 kg
starting price   £2,300
Length YAM 310TAf is 307 cm, the seats can be located both on one bench and on two. There is a locker on the nose. If you arrange the seats on one bench, you will get additional space for another locker. Prices on YAM 310TAf start at £2,300.
Flagship YAM 350TAf
flagship model YAM 350TAf has a length of 350 cm and can develop power up to 25 hp. Prices for this long model start at £2,800.
Specifications YAM 350TAf:
Length   3.53 m
Width   1.59 m
Engine power   18.4 kW/ 25 hp
Folded dimensions   310 x 120 x 63 cm
Case weight   78 kg
Maximum load capacity   550 kg
starting price   £2,800
09.05.2024, 14:36:57
09.05.2024, 14:30:56
09.05.2024, 14:24:16
08.05.2024, 11:40:02
topic Немного о ветре
07.05.2024, 16:13:37
06.05.2024, 23:51:36
05.05.2024, 00:07:47
01.05.2024, 15:50:03
topic Арктическое меню
28.04.2024, 17:02:40
26.04.2024, 00:13:13
605 Сообщений
  • Точка Гостей: 531
5 6 7 8 9 [10] 11
