Автор Тема: The Ankida Yacht concept  (Прочитано 2767 раз)
« : 28.04.2016, 20:52:29 »
The Ankida Yacht concept was developed aiming to move away from the conventional center-line arrangement by integrating the mast, keel and sail configuration with the hull naturally. The bow like arrangement of the vessel allows effective propulsion through the rig generated force.
The sail layout and its operation have been designed to cover the surface area and best possible positioning to the wind condition and direction. Moreover, enhanced performance has been ensured by automatically adjusting the keel bulb to optimize the center of mass. The design relies greatly on the fully automatic operation mechanism; therefore a magnetically levitated turbine has been placed between the masts to provide power for the entire system which makes Ankida a unique and efficient wind powered vessel.
Each port, mast and starboard is running parallel, rather shadowing one another, which enhances the sail efficiency by covering maximum area. When the yacht is not with the sail, the booms remain joined with the aft and allow the sail to furl automatically in the line of the straight mast. Ankida can run under one sail too, therefore, the option of additional sails offer flexibility of pleasant cruising.
  • Точка Гостей: 539
