Автор Тема: GHOOK – New way of mooring  (Прочитано 5946 раз)
« : 19.06.2017, 21:36:18 »
Mooring has never been easier
The GHOOK by boatasy consists of a handle with an inserted rolling wheel and a safety latch. Additionally, a tow rope can be adjusted for even easier handling.
Due to its simple use it could be used by different crew members on different type of boats.
Clean Hands and Decks
With a connected tow rope to GHOOK, the mooring line can be transferred at the side at a lower position, under the boat gunwale without any fear of it touching the boat’s fenders.
Mud and shells attached to the mooring line, will fall into the water instead of onto the deck. Holding the GHOOK instead of the rope also protects the crew’s hands and provides a much smoother and speedy mooring experience.
Transfer Up to 3-times Faster
The mooring speed is particularly cruical in the case of windy conditions, which can cause drifting, possible collisions, hand injuries – or at the very least – a lot of stress. For that reason the GHOOK design is now providing the optimal speed and strength performance. Special attention went into minimizing the friction caused by overgrown ropes. Algae and shells do not present an obstacle to the GHOOK.
When compared to traditional mooring, using the GHOOK accelerates the mooring process by up to 3 times.
topic Нетерпимая влажность
05.05.2026, 13:19:55
27.04.2026, 20:41:16
22.04.2026, 23:52:47
topic В кейптаунском порту
22.04.2026, 18:40:20
3060 Сообщений
  • Точка Гостей: 465
Май 2026
3 4 5 6 [7] 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31
