Автор Тема: The smart UV protection  (Прочитано 7793 раз)
« : 26.03.2016, 18:09:30 »
The intelligent SD UV sensor interacts with Neviano, being in connection with the app Spinali Desig and the IAGO system.
Men, women or children, the user can be notified in case of risk of sunburn thanks to the sensor interaction with the mobile app for IOS and Android. Its set up and development by means of SD Connect allow to parameter your SD UV sensor with your skin type and your sunbathing habits.
The Neviano application for IOS / Android presents a detailed graphic interface and an easy navigation. It allows you to use all Neviano's functions, being in connection with SD Connect and Protect UV . The intuitive menu ensures that the user can choose between a range of different useful and sensual functions. The app integrates the multi-sensors function, the Distance function and the Valentine function.
The Distance function
All UV sensors interact with the app for smartphones; they have a system that notifies you when your child goes beyond a radius greater than 50 meters.
The multi-function sensors
The multi-sensors management option allows you to control multiple sensors at a time. You can control the UV rate of your children to protect in the best way from the risk of sunburn.
The Valentine function
The Neviano application has a Valentine function that allows to alert the partner who should apply the sunscreen on your body before you receive the notification. An innovative, playful and sensual mix that combines business with pleasure.
« Последнее редактирование: 26.03.2016, 18:41:41 от bigbird »
05.02.2026, 17:58:52
05.02.2026, 17:49:01
05.02.2026, 17:29:05
topic Timex Intrepid: перевыпуск легендарных яхтенных часов
[Новинки]
04.02.2026, 21:02:58
topic Когда парус становится разумным
[Новинки]
30.01.2026, 17:01:18
topic В британских ВМС ужесточили нормы потребления алкоголя
[Образ жизни]
29.01.2026, 14:34:33
topic Project Dragonfly: катамаран со складными мачтами
[Новинки]
29.01.2026, 00:50:28
topic День открытых дверей в Нахимовском военно-морском училище Калининграда
29.01.2026, 00:42:01
topic Что это там гудит?
26.01.2026, 20:09:14
topic Медицинская помощь в море: что важно знать
[Полезные материалы]
25.01.2026, 22:36:11
topic Ищем в команду человека с парусными правами Минтранса
[Круизы]
Пианист Сердюк
24.01.2026, 17:50:43
topic Крупнейшее в мире полностью электрическое судно ведет ходовые испытания
23.01.2026, 11:13:56
3057 Сообщений
  • Точка Гостей: 649
Февраль 2026
1 2 3 4 5 6 [7]
