Автор Тема: First look: Beneteau Oceanis 34.1  (Прочитано 3674 раз)
« : 30.10.2021, 01:54:04 »
Theo Stocker takes a look at the Beneteau Oceanis 34.1, the new replacement for the Oceanis 34, which is set up for simple sailing
The Beneteau Oceanis 34.1 is a completely new replacement for the previous Oceanis 34 and follows the formula of the current Oceanis range: wide beam carried well forward, a full-length hull chine, double rudders and two wheels.
The aim of these changes is to create maximum volume on and below deck, while also creating more form stability and power when heeled, but still keeping the waterline relatively narrow for better light winds sailing.
On deck, she is set up for simple sailing.
A self-tacking jib is standard, as is the slab reefed main, but in-mast furling or a square-top main are also options.
The mainsheet is taken aft to just forward of the helms on each side.
The fractional rig has swept aft spreaders and no backstay, keeping the aft end of the cockpit clear.
There are three keel options of deep, shoal and hydraulic lifting keel.
Seats aft of the wheels give the helm a perch on an otherwise open transom with fold-down bathing platform.
A permanent cockpit table provides stowage and bracing.
Below decks, the Beneteau Oceanis 34.1 comes in two or three cabin versions.
Double doors into the forward cabin, a fold-up, aft-facing chart table to port and an L-shaped galley to starboard, along with hull windows and coachroof opening hatches make this boat feel spacious.
Tank capacity of 130L for diesel and 231-361L for water should give reasonable quantities for cruising with a family, all for around £200,000 VAT paid and ready to sail.
Specifications of the Beneteau Oceanis 34.1
LOA: 10.77m (35ft 4in)
Beam: 3.57m (11ft 9 in)
Draught: Deep: 2.0m (6ft 6in), Shoal 1.5m (4ft 11in), Lift 1.25-2.55m (4ft 1in-8ft 4in)
Sail Area: 49m2 (527sq ft)
Disp: 5,470kg (12,059lb)
Price: ca. £150,000 ex VAT
Theo Stocker
topic Поворот верфи Elan Yachts
[Новинки]
08.11.2025, 00:03:44
topic Паэлья с морепродуктами от моряка Кирилюка!
06.11.2025, 18:02:16
topic «Как корабль назовешь...»: 10 историй о необычных названиях команд
03.11.2025, 22:12:07
topic Первый грузовой Ro-Ro парусник прибыл в Балтимор из Франции
03.11.2025, 21:02:46
topic «Палуба дымилась, как кратер вулкана». Кто погубил "Новороссийск"?
01.11.2025, 01:17:56
topic Стала известна дата отправления пассажирского парома из Сочи в Трабзон
29.10.2025, 22:09:29
topic Bars Sailing Team — обладатель Кубка России J/70
28.10.2025, 01:46:25
topic Sea Scow 33
[Новинки]
27.10.2025, 11:26:53
topic Готовим мидии в белом вине с чесноком и петрушкой!
24.10.2025, 23:33:53
topic По Волге на крыльях нового Метеора Водолета
24.10.2025, 22:25:31
topic Вахтенная доска
23.10.2025, 00:06:13
22.10.2025, 23:57:43
3040 Сообщений
  • Точка Гостей: 328
Ноябрь 2025
[9] 10 11 12 13 14 15
